What Kind Of Spark Plugs?
Old Aug 24, 2003 | 03:52 PM
Kuruption562's Avatar
What Kind Yall Runnin?
What Kind Is Good For My Ride?
Old Aug 24, 2003 | 04:04 PM
Damon's Avatar
I swear by plain old Autolite copper plugs. $1.29 each at the local parts store. No, they won't last a billion miles but 30,000 in a stock motor is not problem and I've never had one fail or exhibit "weird" behavior like I have with platium plugs from time to time.
My personal favorite for a stock cast iron-headed SBC is the Autolite #24. It's a heat range or so colder than stock, which is good on a performance-oriented motor AND they are a semi-shorty design that clears just about any header or exhaust manifold I have ever used them with. The hex-head also sits out a good distance so if you have a header tube that you can't get a socket past you can just use a 12-point or open end wrench to tighten/loosen it easily without busting a knuckle. They're designed for a gap of approximately .045" which is about perfect for a factory electronic HEI-style ignition on a N/A motor (small or large cap distributor).
Old Aug 24, 2003 | 04:09 PM
DarthIROC's Avatar
From: Teeter-tottering between Brilliance and Insanity
I run Accel Header pugs.
Old Aug 25, 2003 | 11:13 AM
aklim's Avatar
NGK V-Power changed once a year.
Old Aug 25, 2003 | 02:09 PM
82355's Avatar
I run nothing but AC Delco.
Martin
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
blkWidow
May 3, 2015 08:42 AM
nikko
Apr 20, 2015 07:56 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
Jazsun
Dec 29, 2014 12:14 PM
