What holds the 305 back!
Old Jul 11, 2008 | 10:08 AM
  #46
Marc 85Z28's Avatar
Originally Posted by burnin_rubber_irocz
Is there anybody out there with a supercharged 305 that could tell me their setup and how they got it that way? my car is 87 not 88 messed that up
Search for a guy named Willie (screenname too) both here and over at TGO. He's got a very nice, very clean supercharged 305 car that runs well. May also want to lookup BADDEST305. He had a low 12 second 305 NA that ran deep 11s I believe when spraying.
Old Jul 11, 2008 | 11:59 PM
  #47
burnin_rubber_irocz's Avatar
Thanks a bunch i will look it up right away. I was also on TGO just last night looking this up too. thanks though.
Old Jul 12, 2008 | 01:09 PM
  #48
BigBlueCruiser's Avatar
Here's a monster 305 build. Takes ported 58cc heads to do this
http://www.thirdgen.org/techboard/tp...tpi-310-a.html
Old Jul 13, 2008 | 02:02 PM
  #49
Kevin91Z's Avatar
3rd Gen Tech Moderator
Originally Posted by rik89gta
Well if it isn't the peanut cam... then why is one 305 tpi with either the A4 or M 5 combo rated at 205 horsepower while the other 305 that's only available with the 305 and M5 rated at 230 horsepower? I know there is an available G92 option, but I can't understand how an extra catalytic converter and an oil cooler would add 25 horsepower... Something isn't adding up here!
Its the exhaust. The 305 5-speeds with the dual-cats have the same exhaust as the 350's with dual cats. Larger 2 1/8" outlets, dual 2 1/4" y-pipe to dual 2 1/4" cats, and a 2.75" cat-back.
The single cat 305's, with automatics and T5's, have the same exhaust as the 305 TBI cars. Smaller 2" outlets, a single 2 1/4" y-pipe with a single 2 1/4" cat, and a 2 1/4" cat-back. Changing the exhaust on these cars will give you the 25 horsepower back.
And if you doubt how much power a good exhaust setup is worth, my father had a guy with a 350 carb'd engine in a Chevy truck come to him back in the early 90's. It had the whole Edelbrock power package on it, including cam, heads, and headers. It dynoed a whopping 160 HP to the wheels. My dad noticed the y-pipe on the Edelbrock headers was more like a T-pipe, with one pipe going into the side of the other. My dad cut that off and remade the connection into a true Y. The owner had it redynoed and it now made 210 HP to the wheels. That's a 50 horsepower gain just from a y-pipe change.
Old Aug 6, 2008 | 08:43 AM
  #50
Geezer powered's Avatar
What really holds back a 305 is the 3500lb car it has to move
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Amshnock
14
Jan 18, 2015 11:47 AM
markaubuchon
Jan 14, 2015 01:48 AM
