What exactly has to be done to do a TH350 swap from 700-R4?
Old Apr 21, 2003 | 05:01 PM
DarthIROC's Avatar
From: Teeter-tottering between Brilliance and Insanity
Im taking the Z off the road and making it pretty much a weekend warrior since I drive my truck everyday now. Im sick of my 700-R4 and Am just going to put a TH350 in it when I do the engine swap.
I heard the only thing thats different is the transmission mount. Is that true or are there other things that are different. Ie.. driveshaft. I just needed to know what exactly I have to do.
Old Apr 21, 2003 | 05:22 PM
Zepher's Avatar
Longer driveshaft if I am not mistaken.
thirdgen.org has quite a few people that have done that swap.
Old Apr 21, 2003 | 05:50 PM
Dave89IROC's Avatar
if you use a long tail T350 you can use the same driveshaft
if you use a short tail(more common) you need a driveshaft about 3 in. longer
Old Apr 21, 2003 | 10:52 PM
transambill's Avatar
Yes with a short tail turbo 350 you'll need a longer driveshaft and with a long tailshaft you don't but you'll still need the B&M switch kit no matter which trans you use long or short tail so you'll be able to attach the torque arm to your trans. and the kit places the mount farther back so it will attach to your crossmember.I've done this particular swap 5 times and it's EASY.If ya have any questions just ask.
David Dempsey
Mar 12, 2016 12:42 AM
blac94Z
Nov 4, 2015 01:59 PM
gonzo275rltw
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
