What cam for a 89 RS camaro 5.0 TBI
Old May 2, 2005 | 02:17 PM
keithystealmaro's Avatar
I heard that sticking a LT1 cam in a 5.0 TBI can be done relatively cheaply is this true, also what other cams should i be looking for??? thanx
Old May 2, 2005 | 02:43 PM
85_305's Avatar
Re: What cam for a 89 RS camaro 5.0 TBI
Well, in a 350 TPI yes it can be done; I dunno about *tbi* or a 305. I would think you would loose a LOT of power by sticking a 350 cam in your 305.
Old May 2, 2005 | 07:35 PM
Ben91RS's Avatar
Actually, putting an LT1 (or even an LT4) cam is a pretty common cam swap for 305 TBIs, and it works great. All you really have to do is grind down the dowel pin and install it just like any other cam swap. Although, like any modifying any other FI setup, the computer will need to be tuned to run at it's best.
Old May 2, 2005 | 08:59 PM
85_305's Avatar
^How do you not loose power for going from a cam designed on a larger engine?
Old May 3, 2005 | 12:15 PM
Damon's Avatar
It's not a very aggressive cam. Duration around 200-205* @050, lift in the low .400 range, nice wide LSA to preserve a smooth idle and keep the ECM happy.
Compared to the original TBI cam it's a fire-breather, but in the grand scheme of things it's still really mild. That's why it works well in the 305 TBI motors as a mild performance cam.
Old May 3, 2005 | 12:34 PM
Tru2Chevy's Avatar
Cams are designed more to work with power curves than displacement. Look in any cam catalog at SBC cams - they are listed as being used for 265ci-400ci small blocks.
- Justin
Old May 3, 2005 | 01:52 PM
85_305's Avatar
I gotcha
Good to see you posting again though Justin; you planning on sticking around or what?
Old May 4, 2005 | 01:39 PM
Tru2Chevy's Avatar
I gotcha
Now that the weather is nice again, I'm on a final big push to get my car out of the driveway, so less time spent on the boards. I've also been busy with the planning stages for the East Coast Nat's, the event my club (NJFBOA) is putting on this August at Island Dragway.
I'm still around don't worry, and you can always leave me messages on AIM.
- Justin
Old May 4, 2005 | 02:52 PM
96m6lt1's Avatar
the lt1 cam is nice however the lt4 is better due to the 115* lobe sep makes more power than the 116-118 cams and tuning on this cam is minor(tbichips etc.)this cam also gets the benefit of 1.6 rockers as well.....
Old May 4, 2005 | 09:36 PM
85_305's Avatar
- Justin
Ya I hear you about the whole "nice weather coming, get the car the HELL out of the garage" thing I need to do about $610 worth of things to my Camaro befroe it's even "legal", let alone insurance. Oh ya.. and all by the beginning of June as well
But I have sent you another PM, btw
1775.Z28
Jan 11, 2015 10:51 AM
92ragtop
Dec 27, 2014 01:56 PM
NewsBot
Dec 24, 2014 11:05 PM
CaRParts102
Dec 6, 2014 08:45 AM
94B&RZ-28
Dec 22, 2008 10:00 AM
