Weight of a stripped down 3rd gen? (race ready)
Old Jul 5, 2003 | 11:58 AM
JoFerZ's Avatar
I'm thinking about finding a cheap camaro (87-92) with or without an engine, and depending what I find, either rebuild the 350 in it or swap in a ZZ4 crate or something like that. Then I'll want to completely strip the car down to the bare essentials...no interior, no dash (build a custom aluminum one), no side windows, and no emissions, a/c, heater, etc. But I'll also want to add a cage. How much could you get one to weigh doing that? I'm guessing you could get under 3000 lbs.
What I'm wanting is a light, powerful, good handling 3rd gen that is pretty well race ready and cheap to maintain (for example going back to a carb).
Does anybody have anything like this or know of any websites that could help me out?
Thanks,
Josh
Old Jul 6, 2003 | 10:58 AM
VortecZ28's Avatar
I want to do the same thing. I'm just going to find a berlinetta with a blown motor or soemthing, get it for next to nothing and start strippin it.
Old Jul 7, 2003 | 10:18 AM
baddest305's Avatar
i got my car down to 3120 lbs. still looking for more weight lose but don't know what else i can take off.
Old Jul 7, 2003 | 12:57 PM
12Second3rdgen's Avatar
If I were you I would look for an 82-84 car. They weigh less and most came with a carb already, so thats less work down the road. I have an 82 Camaro, and it weighs 3050 pounds with all interior plastics, a steel hood, steel heads, a full size starter and all carpets.
I have done the following for weight conservation:
Weld Pro Star Wheels
Removed Power Steering
Removed all A/C Components
Removed All smog
Removed ECU and harness
Aluminum intake
Summit racing seats (plastic)
I can't think of everything I have done right now, but thats most of it.
Old Jul 9, 2003 | 03:15 PM
350ws6's Avatar
Hey guys-quick question. Have any of you weighed your car already? I have a 1992 ws-6 Trans Am, all power options no t-tops and it weighs 3140! Its not a mistake either, i have the print out from the track scales, the car is 100% stock as far as weight goes, no gutted interior or anything. The only thing thats different is the manifolds are ditched for the TES headers. Does this sound reasonable? Thanks
Old Jul 9, 2003 | 06:51 PM
Slow91z's Avatar
Wow that's light...you might want to go back and make sure the scales are calibrated...If so that's one light F-body
Old Jul 9, 2003 | 10:52 PM
350ws6's Avatar
Yeah thats what I'm thinking, the next run I checked it and it was 3157. The scale must be off i guess, anybody have a 1992 TA and weigh it?
Old Jul 9, 2003 | 11:04 PM
Slow91z's Avatar
I just guessing, but 3500 sounds close
Old Jul 10, 2003 | 04:53 AM
aziroc's Avatar
IMO if ur going to make a drag only car.. y get a 350? id just save up and get a 572 and just bore the **** out of it.
Old Jul 10, 2003 | 09:11 AM
Old Jul 10, 2003 | 09:25 AM
aziroc's Avatar
.. a chevy big block 572 and make it into a 600+ cu in engine
Old Jul 10, 2003 | 11:09 AM
Boring a motor solely for more displacement isnt common practice. Did you mean stroking the motor?
Old Jul 10, 2003 | 12:23 PM
aziroc's Avatar
as long as its 600+ cu in i dont care
Old Jul 10, 2003 | 03:36 PM
Slow91z's Avatar
Wow...So you would shorten the life of an engine (by taking away the possiblity that it could be rebuilt) By years just for 600 Cubes...when it doesn't even make that much more HP per dollar?? I mean the name of the game is HP per dollar, getting every foot pound you can on your budget, whether it be thousands or hundreds.
Old Jul 10, 2003 | 03:54 PM
aziroc's Avatar
id rather have loose life time of an engine (cause we all know built 600 cubes used for drag racing last 100,000 miles ) then use some run of the mill 350.
my whole point before u got all bent out of shape was y do all this work and just put a 350 in there.. put a big block in there.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
jbrockwell
Mar 14, 2015 08:44 PM
Doug Harden
11
Jul 14, 2002 04:31 PM
