Water temp gauge connection?
Old 10-27-2003, 07:55 PM
StealthElephant's Avatar
I can't find out where my water temp gauge comes through the firewall....is it a green wire?
Basically, I also can't find what it goes on to, I have everything hooked up, speedo, tach, oil pressure, all I need now is my water temp and I have 1 wire left that has no home, its green.
Where on my TPI did the water temp sensor go? Front of the cylinder head? Because the block has a water temp sensor, but it doesn't work, I think that one went to the computer. I need the one that hooks up to the gauge...any ideas?
thanks
StealthElephant is offline
Old 10-27-2003, 08:11 PM
smokiniroc87's Avatar
i think its on theres one on the driverside of the block in the middle right under the headers, unless thats the one your talkin about. if thats not it then i dunno.
smokiniroc87 is offline
Old 10-27-2003, 08:32 PM
There was one on the passenger side of the block under the exhaust manifold, we tried, it doesn't work. Now there are two possibilities, that the green wire doesn't go to the gauge, or that the sensor on the passenger side is the computer temp sense and not the gauge temp sens.
Old 10-28-2003, 12:53 AM
aklim's Avatar
It is a green wire that is a little thicker than most but thinner than a cable. It has a clip on the end.
aklim is offline
Old 10-28-2003, 08:33 AM
Ok so I know that the 1 green wire left on my harness is indeed my water temp. So where is the original sensor on the 305 TPI that i can put on my 350?
Old 10-28-2003, 05:06 PM
Dave89IROC's Avatar
thew gage sender is in the drivers side cylinder head, between the first two spark plugs
Dave89IROC is offline
Magenta_Hearts
03-29-2017 08:54 PM
94Z28LS1toLT1
01-15-2015 07:18 PM
cmdeshon
12-27-2014 10:06 AM
brentbrowning01
12-16-2014 06:35 AM
ro2207
12-04-2014 06:18 PM
Quick Reply: Water temp gauge connection?
