votec intake torque specs
Old Mar 13, 2005 | 11:19 AM
billyhoss's Avatar
iam going ot install a spdc vortec tpi intake on my motor but can not find the specs to torque it down at, i see that if iam using the factory plastic intake gaskets its 11lbs but iam using fel-pro 1255 fiber ones and iam sure its higher then the 11lbs, any help would be great, thanx
Old Mar 13, 2005 | 04:54 PM
Marc 85Z28's Avatar
Re: votec intake torque specs
Back before GM incorporated the steel washers in the gaskets to prevent gasket warpage, I used Fel-Pro because they used it. 11ft/lbs is what I used, and I've never had a comeback.
Russ95Z28
Apr 23, 2015 01:55 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
pimpss96
Feb 12, 2015 01:28 PM
CARiD
Jan 27, 2015 06:27 AM
