Valvespring recommendation?
Old Jan 3, 2007 | 11:12 AM
12Second3rdgen's Avatar
Hey I am looking for a valve spring recommendation. Heads are 235cc Pro Topline Aluminum cnc heads with 1.55 spring pockets. I will be running a custom ground billet roller camshaft that I bought off ebay, specs are 262/266@.050, .665/.625, 106*LSA. I am trying to find a valve spring that would work for my setup. I do a little bit of street driving, mostly drag though. Trying to do this on a budget.
Thanks!
Old Jan 3, 2007 | 11:18 AM
CustomSSI's Avatar
What are those specs with what ratio rocker?
Old Jan 3, 2007 | 12:04 PM
Specs are with a 1.6 rocker, I can provide any other information you might need.
Old Jan 3, 2007 | 04:30 PM
84firebird's Avatar
the cam manufacturer should supply you with a spring to use... otherwise if your rate or open or closed pressure is too far off you're going to float em,
it's dependent on cam and it's profile, like aggressive means higher pressure, but too high and you'll wipe it... there's no real way to tell what springs to use without the profile, and you shouldnt have to
Old Jan 3, 2007 | 05:16 PM
AutoRoc's Avatar
Odd place to look for that info! Try Yellowbullet.com in the camshaft forum, Cam Master Jay would know as well as many other racers. They run some serious hardware over there. Goodluck! Is this going on the 350 crate? That's a lotta head! 8500rpm?
Old Jan 3, 2007 | 05:59 PM
lol well kind of, I bought my crate engine brand new when I was in high school so there is a lot of sentimental value which is why I reused the 1 piece rms block . Engine is:
377 (4.00x3.75)
12:1 compression
Forged pistons, forged rods, Eagle ESP crank
Solid Roller as described
Pro Action 235cc cnc heads w/ 2.08 1.6 valves
Hooker 1 7/8" headers w/ 3.5" collectors
Single Plane Intake w/ 1050 Dominator
Turbo 350, 4200 converter
I am hoping to turn 7000 or so, I am pretty excited to finally get it together though. I am trying to build a fast drag radial car, shooting for low 11's or high 10's.
Since this cam is a billet roller, I was thinking there would be less change of losing a lobe and more likely to break a lifter or something. I have nice Crane roller lifters so not too worried there. I looked on Comp's website and found a camshaft with nearly identical lift, @.050, LSA and advertised duration. I was thinking of running them, they ar ethe comp 943-16 Valve springs.
What do you guys think?
Old Jan 3, 2007 | 07:07 PM
84firebird's Avatar
377 (4.00x3.75)
12:1 compression
the problem is you still dont have any idea about its profile, like how fast its ramps are and such, i'd ask on that site he posted and see, rollers are less likely to wipe but, if you bind or pinch a roller you're in worse shape than a flat tappet cam...
Old Jan 4, 2007 | 12:37 AM
Kevin91Z's Avatar
3rd Gen Tech Moderator
Manley Performance has several valve springs that will work for you.
http://www.manleyperformance.com/pdf...Comp-51-76.pdf
Take a look at the 22441-16 on page 16 of that document.
Beave2780
Sep 23, 2015 12:37 PM
tommalcolm
Sep 11, 2015 03:39 PM
Schul365
Aug 25, 2015 05:47 PM
POLOVETTE 94
Aug 21, 2015 07:11 PM
jl1ne
Jul 7, 2015 08:38 PM
