v6 in a 305 tbi car?
i have an opportunity to pick up a 305tbi car that is in great shape minus trans/motor setup. everything else is there though as far as cpu, harness, etc just not the actual mechanics.
how hard would it be to retro fit a v6 of the same year? what major things would i need to change as far as would the harness, cpu fit? what else?
Re: v6 in a 305 tbi car?
Look around on tgo, it will be the same as a TBI > TPI swap as far as electronics / wiring go inside the car for the speedometer wiring difference, the tbi computer is different than the V6/TPI one, and of course the entire wiring harness under the hood is different, and you'll need a tpi fuel pump.
ok so i need a tpi harness then, computer, pump, etc.? that's enough to not even make the saw worthwhile if you don't have a good harness around.
i'll have to see what i have... thanks.
You need the V6 engine harness, you need to make the same changes to the inside harness as the guys that go from TBI to TPI for the speedometer, as the v6 and tpi inside wiring harness is the same. Yes you need a high pressure pump.
oldschool
Feb 9, 2016 09:21 PM
bossco
Nov 29, 2014 10:18 AM
