Urgent Question
Old Dec 23, 2003 | 11:52 AM
ULTM8Z's Avatar
Urgent Question
Guys,
Anyone with access to their 7730 ECM (1990-92 TPI Camaro/Firebird), I could use a big favor. I'm trying to diagnose an idle misfire and I was doing a circuit check on my EFI harness. At the distributor reference wire (ppl/wht stripe on the ECM connector), it's showing .6 volts on mine, but the manual says it should be 2.3 volts (with the engine running).
Could someone please take a voltmeter to that wire on their car and let me know what you see? I'd really really appreciate it.
Thanks in advance.
Old Dec 23, 2003 | 12:06 PM
90rocz's Avatar
Ignition missfires occur throughout the rpm range...idle misses are usually vac leaks, or valve sealing problems(dirty lifters etc)..
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
MJ_Z28
Aug 7, 2002 07:15 PM
