upper bolt on T56 pedal swap...
Old Mar 10, 2003 | 12:21 PM
irocz383's Avatar
Hey guys! I put oin the pedals and after I had put it in I relaized that the very top bolt slot doesn't even come close to lining up with the hole in the car.
Is that bolt really necisary? Could I just ignore it? Or should I longate the slot until it does match up with the hole?
Thanks!
Old Mar 10, 2003 | 07:21 PM
TheGreatJ's Avatar
You could probably get away with leaving it out, but don't be surprised when your clutch starts creaking. I would take the time now to get a bolt in there and KNOW it's not gonna be a problem later.
Old Mar 10, 2003 | 11:42 PM
mr diabolical's Avatar
mine hasnt had one for over a year. i just make sure the 4 firewall bolts are good and tight ocassionally. they also all 4 have a backup nut on the firewall to lock the first nut.
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
KYWes
Apr 3, 2015 07:59 PM
maybe2fast
Mar 16, 2015 09:45 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
