unusual vats problem
Old Apr 28, 2010 | 09:00 PM
sled 28's Avatar
I have installed a 1989 firebird throttle body in a 1988 camaro what i changed is the engine trans under hood wiring computer and steering column now the car (camaro) wont run..i have fuel pump and crank circuit but NO pulse signal is there a relay that plugs in by the steering column? I got the camaro as a theft recovery and lots was missing hence the changeover
Old Apr 30, 2010 | 10:50 PM
cars3's Avatar
I want to ask if your security light is on, but I can't remember if 1988 camaros had it or if it started in 1989. ( your thread says vats problem )
Old May 1, 2010 | 10:42 AM
quickchicken's Avatar
GTA got VATS in 88, 89 it went GM wide. are you using the same key and main module thats bolted on the back of the dash? if you have both of those then you have something else going on. check at the bottom of the coulmn where the wires come out to see if you have 2 very fine yellow, white, or orange wires on a 2 pin plug, iv seen GM use a diff color per year. if this lil plug is un done that could be a issue. like CARS3 said, does your security light come on? if so thats a VASTS sign.
Heathen1
Jan 2, 2016 04:27 PM
Klypto
Mar 9, 2015 04:25 PM
Noer
Feb 28, 2015 11:29 AM
Lakebratt
Feb 5, 2015 07:55 PM
Fedesna
Nov 23, 2014 11:06 AM
