turbo 350 swap
turbo 350 swap
I have a 90 Iroc -z with a 700r4 trans. I have a street/strip turbo350 in my garage that I want to put in my car. I am pretty sure I need a new driveshaft/ crossmember, and some kind of torque arm mount. the turbo 350 has the short tailshaft on it, so what would i need to make this possible?
thanks
thanks
with a short tail 350 u will need a longer drive shaft and a conversion kit that allows u to mount ur tq arm to the trans b&M MAKES ONE IT WILL COST ABOUT 90 DOLLARS I HAD IT ON MY CAR AND IT WORKED GREAT
u can get the conversion kit a paw the # is 1-818-678-3000
the part # is b&m-30299 itz called the th-700 to 350 changeover kit
if u go to a local trans shop they should be able to tell u where to get a drive shaft for it u might have to got one made in the 82 camaros the drive shaft from that would fit i think
a friend had a th350 built up in his camaro, and had the 700 tail shaft installed while it was built, but I cant remember if he got to keep the same driveshaft...I'm almost sure he did! But I do know that he used the 700 tail shaft so he didnt have to buy the torque arm mount...
Adam
Adam
cmsmith
Apr 11, 2015 09:37 PM
