Tuned port injection
Old Jan 11, 2007 | 06:56 PM
mhanley4298's Avatar
I have acquired a fuel injection system from an 86 Trans am.It is complete with manifold,runners and throttle body.Also wiring harness and engine computer module,Fuel rails and injectors,etc........
Will this unit work on my camaro project motor.Ive got an 87 RS that I want to modify,the motor that is.Its going in my T-bucket if I can make it work>
Old Jan 11, 2007 | 07:38 PM
89TramsAmGTA's Avatar
If you have everything I don't see why not. Sounds like you have a 305 motor?
Old Jan 11, 2007 | 11:03 PM
Yeah,but will the engine computer need to be modified(remap on dyno?) or
Can this unit be chipped(high performance chip?)and will the injectors need to be replaced with a product from JEGS or whom ever makes those aftermarket injectors,I cant remember,my catalogs are at work.
Anyway Im kinda looking for a quick education in TPI as this is somewhat new
to me,I.E. Im spending too much time trying to gain knowledge which is why
I love to get with you guys to cut right thru the B.S.
Old Jan 12, 2007 | 03:55 AM
Zepher's Avatar
As long as all the parts are good, you are good to go.
you may want to head over to www.thirdgen.org and search in the TPI section to learn more about TPI and doing the swap.
I did a couple of swaps about 5 years ago, one on my 86 Trans Am and one on a camaro with my setup when I went with an LT4/T56 setup.
Old Jan 12, 2007 | 04:01 PM
TPI injection
Thanks,That was very helpful tech link
Old Jan 13, 2007 | 05:49 AM
Marc 85Z28's Avatar
Not so fast. That intake will not bolt up to the cylinder heads you plan on using. 85 and 86 TPI intakes used the standard SBC intake angle, as the engines up until 87 used that angle. 87 and later with the centerbolt valve cover heads used a different intake bolt angle on the center intake bolts. You will need to modify your TPI lower intake, machine the heads, or use a later TPI lower intake.
Old Jan 13, 2007 | 08:08 AM
mdacton's Avatar
he is right on the intake bolt patern 86 was the last year with the reg sbc bolt pattern, A machin shop can easily fix the intake tho
Old Jan 13, 2007 | 12:26 PM
Correct but as stated above that is easily fixed.
Old Jan 13, 2007 | 05:26 PM
TPI injection
Thanks guys!!without that info I would have been in for huge surprise.
Most helpful
Old Jan 13, 2007 | 06:43 PM
formul8's Avatar
Arrow
Try here:
http://chevythunder.com/
www.thirdgentech.com
DSMKilla
May 26, 2015 10:10 PM
rockync7
Jan 1, 2015 05:10 AM
Jul 4, 2005 05:00 PM
97FormulaWS-6
Aug 5, 2002 05:15 AM
