trying to pick up free HP will this work???
Old Oct 3, 2003 | 11:07 PM
lordmetalz28's Avatar
ok tonight i disconnected the brown wire with the black stripe above my hvac fan to reset timing back to stock. now i adjusted the distrubutor by 2 degrees up.my question is how does my distrributor go back to normal. if i turn it anymore ill have no play with the wire id assume do i disconnect the timing switch and turn it clock wise . also i was wondering if you can sorta get some advance in the tps buy turning the sensor up twoards the hood or down twoards the ground.i took my tps plug off while the car was running and the idel jumped up to aout 1700 after i reconnected it it wouldnt go down i had to shut the car off and restart. also going around a trun tonight( on a bumpy road) i punched the car around the turn and heard like a slam come from some where if my axels where broken or my rear was broken would i know it. nothing chaged afterwards she still ran beautifuly and if my body shifted on the axel would i know that to. ok ok well good news is tommrow i take off my cat and replace it with a 3inch straight pipe. woo who any ideas on what kinda hp ill get out of that and how much torque.
DirtyDaveW
Dec 1, 2016 05:37 PM
Britbilly
Jan 7, 2015 08:49 PM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
siguy
Nov 27, 2014 10:07 AM
Elcojoe
Nov 17, 2014 10:27 PM
