Transmission problem
Old Apr 21, 2007 | 08:15 AM
splinter_cell's Avatar
Well today on my way to work my transmission wouldn't shift. I have a 700R4 tranny that was rebuilt 3-4 years ago. I backed out of the driveway and when I put it in drive and got to around 10-15 mph. I was waiting for it to shift but the rpm's just kept climbing I pulled a u-turn then went back to my house. I didn't really get a chance to check it out since I was late for work. I just got home and wanted to know what the problem could be and what I should look for tommorow. the fluid level is fine.
When I was coming back to my driveway I put the car in nuetral and revved it up just to make sure I wasn't in second gear or something. My car was fine on Tuesday. I put a new thermostat in yesterday but didn't drive it so this happened out of the blue. I put a new filter/fluid in about 3 months ago and adjusted the tv cable about 2 weeks ago. Any help is appreciated.
Old Apr 21, 2007 | 08:22 AM
IROCmustangs's Avatar
Samething happened to me a couple of weeks ago. Except mine wouldnt shift into 3rd. I ended up having to get the transmission rebuilt.
Old Apr 21, 2007 | 08:24 AM
That sucks. I hope I don't have to get mine rebuilt again.
Old Apr 21, 2007 | 10:43 AM
antoine's Avatar
check the govorner gear teeth
Old Apr 24, 2007 | 10:43 AM
Rage's Avatar
I have a 700R4 that has about 20K on it. Let me know if you're interested.
Old Apr 24, 2007 | 07:12 PM
lordmetalz28's Avatar
adjust the throttle cable.. specially if youve been working on it or near it,,,, chances are its needs to be adjusted
Old Apr 25, 2007 | 05:06 PM
Got my replacement governor gear in the mail today. So I took the governor assembly out and it is infact the governor gear. Like half of it is gone Do I need to worry about the chunk missing? I don't see how be able to check around for it in such little space. Or do I just need to do a filter & fluid change and be done with it? And to get the gear off all I need to do is take that metal pin out and then I should be able to pull the gear off?
Old Apr 25, 2007 | 10:18 PM
antoine's Avatar
tap the pin out and install the new gear.
Old Apr 25, 2007 | 10:21 PM
Ok one more question, the new replacement gear does not have a hole for pin to slide through. Is it going to be a press fit then?
Old Apr 26, 2007 | 09:29 AM
antoine's Avatar
It should have came with the hole already but you can use a drill bit a little smaller than the pin,install the gear and drill thru then install the pin.
Old Apr 26, 2007 | 12:03 PM
12SCNDZ's Avatar
Push the new gear in, and then drill through it, using the holes in the governor as a guide. You'll need a .110" drill bit. Be careful to get the bit oriented so that you drill through the plastic gear, and connect the original holes in the governor, itself.
Sorry I didn't see this post earlier. Many times you have a "no upshift" in a 700, it's the governor. It would've helped if it were in the "Drivetrain" section.
Frank
CPT
warmeck
Mar 16, 2015 07:02 AM
jmadoll
Mar 3, 2015 10:16 AM
jackpawt883
Feb 26, 2015 09:04 PM
edxiel
Jan 24, 2015 07:40 PM
Cam's maro
Dec 28, 2014 09:30 AM
