Transmission Leak
Old Jul 30, 2010 | 06:41 PM
native1031's Avatar
Transmission Leak
Dont know anything about trannys. What could be causing it and what are some ways of finding out? One problem after another
Old Aug 1, 2010 | 08:02 AM
87DJP2001's Avatar
Could start by saying if it is a manual or auto and a rough location where the leaks is at. Some people can give you good advice but they are not minereaders,
Old Aug 4, 2010 | 12:53 AM
native1031's Avatar
Sorry dutch bag. Automatic and I beleive its the seals leaking.
Old Aug 4, 2010 | 05:21 AM
87DJP2001's Avatar
"dutch bag" if it means what I think....no help here and I hope you burn it up.
Old Aug 4, 2010 | 11:20 AM
Z28SORR's Avatar
Is that, douche bag??? If your going to insult someone you should at least have a grasp of the english languge. Ignorance is the sort of thing that get you band!
Old Aug 4, 2010 | 05:16 PM
Camaro X's Avatar
I don't know a lot but I have had a couple with leaks over the years. If it is just a few drips see if you can tell if it is leaking from the pan gasket. I had that problem on my '68. I just changed the fluid and filter in it last weekend. I replaced the pan gasket and then put in new fluid and Bars Stop Leak. No drips or leaks anywhere.
Many years ago I had a '73 that left a puddle. It needed a rebuild. I went through a quart of fluid every other week!
So, If it is just leaving a drip mark you may be get away with some stop leak, if it is shifting OK and you don't notice any problems when driving.
If it is leaving a puddle, you probably have a bigger problem.
Good luck!
Old Aug 5, 2010 | 06:27 PM
TedH's Avatar
People are trying to be of assistance. Not all of us have outstanding language skills. Please refrain from calling other people names, especially when they are offering assistance/guidance or simply requesting enough information to provide some sort of reasonable answer.
warmeck
Aug 24, 2024 08:05 PM
rideordie
Nov 5, 2019 04:52 PM
Magenta_Hearts
Mar 29, 2017 08:54 PM
jmadoll
Mar 3, 2015 10:16 AM
jackpawt883
Feb 26, 2015 09:04 PM
