transmission coolers
Old Feb 8, 2004 | 08:44 PM
Shane87Irocz's Avatar
what trans cooler should i get i have a 700r4 i am going to help the transmission because i will be runing 12's soon.
Old Feb 8, 2004 | 09:49 PM
KnightRider350's Avatar
I'm very pleased with my B&M. Don't have numbers for you, but it was easy to install and seems to work nicely.
Old Feb 8, 2004 | 10:35 PM
where did you buy yours, it wouldn't be the black one on thunderracing.com
Old Feb 8, 2004 | 10:36 PM
Bought mine at the local Checker...but yeah, summit/jegs/etc will have the same one. It was approximately $50. Well worth it in my opinion.
Old Feb 9, 2004 | 10:28 PM
aklim's Avatar
Unless you are getting really fancy, I would say the one from Jegs, Summit or even U-Haul will work.
Old Feb 10, 2004 | 12:24 AM
cronsformula350's Avatar
a cooler with at least 16,000 gvw rating. Try to run the largest tranny cooler you can. For every 20* cooler you keep your transmission, you double its life. The hottest you want the trans fluid to get is 170* F. At this temp, the fluid can last 100,000 miles, any hotter and its life is significantly shorter.
Old Feb 10, 2004 | 01:29 AM
kevin 2.8's Avatar
what about over cooling. ive seen someone put a one way valve thermostat on it to keep the temp from dropping too low.
http://67.104.247.214/jmb/firebird/home.htm
click mods and look down at july 2003
Old Feb 10, 2004 | 01:43 AM
aklim's Avatar
Where are you mounting it? It should sit in front of your condenser which is in front of your radiator. You really don't want to disrupt the airflow too much.
Sep 27, 2015 01:55 PM
cristian1311
Sep 12, 2015 08:16 PM
Daluchman1974
Sep 11, 2015 06:12 AM
92_RS_305
Sep 8, 2015 07:47 PM
rideordie
Sep 7, 2015 08:22 AM
