tpi
i want to run a 327 or zz4 with slp or accel runers , accel intake ported plenum, 52mm throttle body, 22lb. inj. my real question is what can the stock ecm do, can i do these changes without getting a cust programmable one(like calmap), will i be able to just get a custom chip, also in the future i was thining of supercharging willi have to change the computer then for sure or can i still just use a chip
A 730 ecm is a 730 ecm that is your choice for SD...if your going to be tuning and making it exact then SD is the way to go, if your not tuning than MAF will be the way to go because its a little more forgiving.
excuse me on the ecm ignorance, but this end is new for me anyways the 730 i'm guesing is a gm com. and if so when i tune it is it comp. reprogramable or is it like burning a chip or is that the same thing?
You could keep your setup and have someone custom a prom for your Mass Air unit with less problems. I know that www.fasterproms.com does do it truely custom to your car and they reburn it twice after taking readings to make sure it is on the money.
AFAIK, Mass Air gives you the true volume of air and SD estimates it. You could stick intakes on a MA system and not have to reporgram the EPROM whereas, to get the max out of an agressive intake on SD, you will have to reprogram. At least that was my experience. SD has less obstructions but is harder to work with in that the window of adjustment is smaller and therefore less adaptable.
