tire pressure
Old May 1, 2008 | 01:01 PM
mrcamaro1956's Avatar
tire pressure
can anyone tell what the tire presure is on a 1986 iroc is , i got 245/50/r16 on them.the door label is missing. someone told me 36 psi another said 40 psi , i have them set at 33 psi . help
Old May 1, 2008 | 03:22 PM
mpilarZ281992's Avatar
I believe its 36 psi on Z rated tires for the car.
Old May 2, 2008 | 10:16 PM
ws6transam's Avatar
36 front, 33 rear works well. That's what I've been doing since the early 90's.
Add 5 PSI to the front for autocrossing or road course work.
Also set the alignment to as much negative camber as you can get, typically -0.5 degrees. It'll help road manners and help tire life.
Old May 5, 2008 | 11:57 PM
90rocz's Avatar
Depends on the tire, some are 32psi, 35psi and 40psi...and I believe some even at 44psi(Bridgstones?)
Tires have recommended pressures stamped into them.
Old May 6, 2008 | 06:36 AM
87DJP2001's Avatar
32/35 PSI is a good range for those tires.
Old May 6, 2008 | 06:37 AM
305fan's Avatar
I don't think so.....tires have MAX inflation PSI.
No one tire is made for just one car---so how could they put a PSI inflation on?
The door sticker, if it has one says the PSI the car manufacture specifies for that model. Of course you can run almost what ever you like---just don't under inflate it.
RichJ
Sep 14, 2002 09:37 AM
Frank95z
Sep 10, 2002 08:30 PM
97bowtie
Aug 25, 2002 11:00 PM
Cap'n
Aug 19, 2002 11:33 PM
wytblur
Aug 5, 2002 02:03 PM
