Tilt Steering slop
Old Nov 24, 2003 | 08:56 PM
Tom85T/A's Avatar
Question Tilt Steering slop
The tilt wheel on my friends Z has got alittle slop in it and I was wondering if there is someway to tighten it up?any suggestions on how to do it?
Old Nov 24, 2003 | 09:26 PM
IrocSS85's Avatar
yes, you have to completely dismantle it to tighten the torx bolts inside the lilt. its a very common problem. if you have never taken apart a column, I wouldnt recommend doin it. you need some special tools to do it. itd prolly cost a few hours at a dealership.
good luck
chris
Old Nov 25, 2003 | 08:03 AM
Jim85IROC's Avatar
you don't really need special tools. I took mine apart, and the only special tool I needed was a slide hammer to pull the pins at the base of the tilt portion of the column. Other tools make life easier, but aren't completely necessary.
Keep in mind though, that the torx bits at the base of the tilt joint are a reverse torx. You need a female torx driver to tighten them, but any parts store will have those for a couple bucks. Don't forget the loc-tite unless you wanna do this again in a few months.
HibachiZ28
Nov 6, 2015 12:53 AM
IndyZman
Oct 22, 2015 02:17 PM
rideordie
Sep 7, 2015 08:22 AM
War Engine
Aug 28, 2015 06:04 AM
Schul365
Aug 25, 2015 05:47 PM
