Third Gen tire sizes that will work ??
Old 10-12-2002, 12:12 PM
  #16
firechicken_3's Avatar
Originally posted by Chris`s85Z28
I just got P255/60R15 out back and P235/60R15 in front there Goodyear Eagle GT II and I love them no clearence problems at all
what width rims, and what off set? i am looking at running those sizes, myself.
firechicken_3 is offline
Old 10-13-2002, 06:23 PM
  #17
Marc 85Z28's Avatar
I ran the same combo as Chris's85Z28 for years. No problems whatsoever on my stock 15x7 wheels. I used to have 235/60r15 all the way around, as was factory for an 85 Z28. The 255/60r15 gave a slightly larger rear tire, still fit and handled decently, and did not affect the speedo. No rubbing!
Marc 85Z28 is offline
Old 10-13-2002, 09:53 PM
  #18
LilJayV10's Avatar
my buddy has 275/50/15 on his 89 t/a, and 265/50/15 up front, and the only clearance problem he has is when he cuts the wheels all the way. 275/6-/15 are a tall tire, and unless you want to look like a 4x4 I wouldnt get them. if you do get that size tire in back, and like a 255/60 up front, put in step side bars so your passengers can safely enter/exit the vehicle.
LilJayV10 is offline
Old 10-14-2002, 08:47 AM
  #19
Gerry's Avatar
Well the 255 x 60 x 15's are on all four wheels and look good. They definitely fill in the wheel well a little better and have more rubber on the road. We clearance checked the left front before installing the other 3 and there is a close fit at the bottom near where the fender turns in, but this shouldn't ever hit unless I'm autocrossing or something.... which I don't plan on with this car.
Thanks to everyone for all the great feedback.
Gerry-
Gerry is offline
Old 10-15-2002, 12:52 AM
  #20
aziroc's Avatar
i use to run 235/60/15s up front and 275/60/15is in back with no rubbing. but no im trying to c if i can stuff some 315/35/17s *17x11*s or 335/35/17s* in there with out tubing
aziroc is offline
HectorM52
07-30-2017 11:46 AM
ChrisFrez
01-18-2015 08:05 AM
ChrisFrez
01-11-2015 03:47 PM
ChrisFrez
12-21-2014 09:47 PM
ChrisFrez
12-07-2014 06:01 PM
Quick Reply: Third Gen tire sizes that will work ??
