third brake light problem
Old Apr 22, 2003 | 02:30 AM
abbreeder's Avatar
Hey,
Today, I was gooing to start modifying my 3rd brake light, and found it was not working, I pulled it apart and tested leads running to and from the four bulbs, after that, I haven't a clue what to do.
BDwyer
'86 Camaro SC 2.8 MPFI
Old Apr 22, 2003 | 07:55 AM
irocz8957's Avatar
bulbs for the 3rd brake lights are really expensive i spent about $30 bucks just to get mine working its really not worth it!
Old Apr 22, 2003 | 10:37 AM
aklim's Avatar
There are 2 kinds. One is around $30 and the other is a cheapie. Mine was a cheapie so I lucked out.
Old Apr 22, 2003 | 07:47 PM
camaronewbie's Avatar
The "expensive" bulbs can be had a Radio Shack for cheap! Take a bulb, look through their light bulb trays, and match - I replaced all of mine with no sweat, and all 4 or 5 of them were less than $30 TOTAL!
Old Apr 23, 2003 | 05:38 PM
IROC5.7TPI's Avatar
I got a better idea....stay tuned
Old Apr 24, 2003 | 07:59 AM
irocz8957's Avatar
yeah i was pissed i spent 30 bucks and now half of them dont work! so i wouldnt mess with it!
Old Apr 24, 2003 | 11:21 AM
krazzycowgirl's Avatar
Try Radio Shack part# RS-2721177 bi-pin halogen bulb
I called around here & they are in packs of 2 for $1.99
Old Apr 25, 2003 | 02:07 PM
abbreeder's Avatar
wrong problem.
I already have new bulbs for the high mount brake, I don't know where you guys are from, but I paid $3 for 2 bulbs. The problem is there is no power getting to the bulbs, I checked the leads and I checked the connectors at the bottom of the hatch lift and they aren't getting power either, I don't know which fuse it's on, I would imagine the same fuse as the other brake lights. I don't see any fuses that are "burnt out". From there I don't know where to check,
thanks for trying the first time,
BDwyer
86 Camaro SC
Old Apr 27, 2003 | 12:13 AM
lordmetalz28's Avatar
try this
ok heres what i think
gm seems to have a little problem with leaky t-tops( no never) lol. 3 weeks ago i was preparing for inspeaction when my thrid brake light all of a sudded stopped working. i went nuts changed bulbs and even the whole light assembly. your answer is to trace your light wires all the way back to the box if your t-tops leaked at one time chances are they leaked on your wires and have corroded them this is the problem i experienced after you totally gut your interior all you need is some wire snips and black tape a big job for a such a bull**** light and also before you go gutting the interior try cleaning the connections on the hatch with a screwdriver scrape the metal and maybe it will be a qwick fix
goodluck
squarehead
Jan 15, 2015 07:02 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
AW/whiteZ-28
Aug 27, 2002 12:53 AM
AW/whiteZ-28
Jul 25, 2002 04:09 PM
