Temp Gauge
Old Nov 3, 2004 | 09:04 PM
LandryP's Avatar
Temp Gauge
I just swapped a a carbed 305 in place of the fuel injected six my camaro used to have and I'm trying to get the factory temp gauge to work. Can anyone tell me what color the wires for the gage are. The 2.8 had two sensors on the intake and dispite jumping, grounding, juicing, ect the wires for them the gage will not move. When the ignition is turned on the gage moves down a bit below the scale and then back to the bottom of the scale when shut off. Any help getting this thing to work would be great
Thanks,
Pat
Old Nov 3, 2004 | 09:14 PM
fbodyfreak's Avatar
Re: Temp Gauge
Are you still trying to use the same ecm? Have you run the car for a little while?
Old Nov 3, 2004 | 10:33 PM
Rice Killer87's Avatar
Re: Temp Gauge
the temp. sender is between the #1 and #3 spark plugs on the driver side head. (the first 2 plugs). i believe its just 1 wire,and if memory serves me correctly i think its green.
Old Nov 4, 2004 | 06:29 AM
LandryP's Avatar
Re: Temp Gauge
The ecm is still in the car and hooked up but its not controling anything, If memory serves my there was a single green wire on the drivers side, I'll check that out after work I just figured it was one of the two sensors on the intake
Old Nov 4, 2004 | 03:28 PM
Re: Temp Gauge
the ecm doesnt deal w/ any part of the temp. guage and sender
Old Nov 5, 2004 | 05:51 AM
Dave89IROC's Avatar
Re: Temp Gauge
the v6 temp sender was in the front corner of the drivers head
Old Nov 5, 2004 | 06:28 AM
LandryP's Avatar
Re: Temp Gauge
Got it, there was a third sensor on the corner of the head with a single green wire
thanks
KYWes
Jun 14, 2022 06:52 AM
Henson071
Dec 30, 2015 09:55 PM
malikot02SS
Aug 15, 2015 01:11 PM
MikeWhitener
Aug 2, 2015 06:17 PM
C4m4roJoe
Jul 19, 2015 10:59 PM
