Temp Gauge
Old Oct 26, 2004 | 03:38 PM
Bruticus's Avatar
Temp Gauge
Bah yet another little issue today i noticed my Temprature gauge wasnt working what could be the cause of this?
Old Oct 26, 2004 | 04:03 PM
Ben91RS's Avatar
Re: Temp Gauge
First thing to check would be to make sure that the coolant temp sending unit wire is still attached. It's located on the driver's side of the motor, in between the #1 and #3 spark plugs.
Old Oct 26, 2004 | 06:18 PM
Rice Killer87's Avatar
Re: Temp Gauge
what he said,and if the wire is on there...get another temperature sender. like 5-6 bux at ur local parts store
Old Oct 27, 2004 | 05:10 PM
Bruticus's Avatar
Re: Temp Gauge
The wire did fall out imma jack up the car tomorrow and put it back in thanks.
Old Oct 27, 2004 | 05:58 PM
Re: Temp Gauge
i can get to mine from the top...
Old Oct 28, 2004 | 03:04 PM
Marc 85Z28's Avatar
Re: Temp Gauge
If you have to jack up the car to service whatever you are seeing, you're looking at the wrong part.
Old Oct 28, 2004 | 05:05 PM
bmillington's Avatar
Re: Temp Gauge
The temp sender is right between the #1 and #3 spark plugs with that yellowish plastic connector. Might be a little harder to get to with stock manifolds.
http://www.geocities.com/millingtonb...-r1-012-4a.jpg
Old Oct 29, 2004 | 02:42 PM
86irocmarque's Avatar
Exclamation Re: Temp Gauge
my temp gauge wasn't working either so after reading this post i checked mine. the wire was hanging loose and it looks like the sensor got broken or burnt off. so i've got the sensor broken off and stuck in the block. anybody got any BRIGHT ideas on how the get the broken piece out.
Old Oct 30, 2004 | 01:04 PM
aklim's Avatar
Re: Temp Gauge
Vise grips? Your sensor is toast already and if it is that broken off that you cannot get a socket on it, might as well go with the vise grips.
KYWes
Jun 14, 2022 06:52 AM
Henson071
Dec 30, 2015 09:55 PM
malikot02SS
Aug 15, 2015 01:11 PM
MikeWhitener
Aug 2, 2015 06:17 PM
C4m4roJoe
Jul 19, 2015 10:59 PM
