taking the steering column apart.
Old Dec 26, 2006 | 03:04 PM
ILOVEGINA's Avatar
alright, i was wondering how the hell you take the ignition out of my 91 z28. do you have to taked the steering wheel out????? because i am getting no power to the start cable. any suggestions. and i also wanted to know, which wire is the coil wire. its a 91 z28, 305 tpi. is it the pink one with the white one coming out of it???? and which one is the tach wire??? is it the little white 20g wire??
all help is greatly appreciated
Old Dec 27, 2006 | 11:10 PM
candymanz28's Avatar
If You Get In The Column You'll Need A Compressor Tool To Put The Lock Plate Back In. Ive Broken 2 Of Them .
Old Dec 28, 2006 | 01:44 PM
xdamagedx's Avatar
The top right has the coil and distributor wiring.
**edit**
this isn't for a TPI but it should be close, let me know if it has different colors for the wiring back there.
Old Dec 29, 2006 | 10:44 AM
2000GTP's Avatar
If you want to replace the ignition switch, then yes, you'll have to pull the wheel. You will need a special puller to remove the steering wheel itself and then you'll need another tool as mentioned above, to depress the lock plate. My best suggestion would be to buy the Chilton's manual because it does a pretty good job of outlining the process. As for the tools, you can pick up both of them from Sears.
Victor Lamb
Aug 26, 2017 02:52 PM
nikko
Apr 28, 2015 10:05 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Jul 4, 2005 05:00 PM
Darth Xed
Jul 1, 2002 03:22 PM
