Under 1000 dollar HP gains
Old Dec 19, 2006 | 06:43 PM
MyNameIsMud's Avatar
i figured this would be usefull to alot of people... i was wondering what mods under a grand are there that add some good horse power and what are the best.
Old Dec 19, 2006 | 10:07 PM
ws6transam's Avatar
Edelbrock 6872 TES header system with new Carsound three-inch slip-fit catylitic converter, and a Hooker Aerochamber cat-back exhaust. Total cost, less than $600.
Comp Cams XE254H cam with lifters, $165
Decent 2400 RPM stall lockup-style torque converter, $200
Total cost, $965 and it'll totally wake up your car.
Old Dec 20, 2006 | 12:47 AM
House's Avatar
Hedman headers summit 135, y pipe 98, muffler 72, exhaust shop to run 3 inch 125
stealth ram
58mm tb
Old Dec 27, 2006 | 01:20 AM
slimdawson's Avatar
Nitrous. Period.
Old Dec 27, 2006 | 10:53 AM
2000GTP's Avatar
Originally Posted by slimdawson
Nitrous. Period.
Yep, one of the best bang for the buck mods out there.
Old Dec 28, 2006 | 11:25 AM
DarkJuggalo's Avatar
i still have yet to get a tq converter. i cant decide on a rpm range. ive been told so many diff ones lol. my car is a street car as well so its kinda hard.
i was lookin at a 2800 and my buddy is telling me 3600 cause of my cam. it wants to pull me through lights but im on a stock converter hehe
Old Dec 28, 2006 | 04:59 PM
AutoRoc's Avatar
Dark Jugs,
your car sounds pretty stout, any clue how much power it makes? Is it carb'd or TPI? 4.10's and a 700R4 is insane, especially if you have TPI. I'm sure first gear is useless unless you already put on some extremely sticky tires. What are the cam specs and what compression do you think the engine is? In my opinion, I'd go with a 3000-3600 depending on what intake and cam you have. If it's aftermarket TPI, i'd go with 3000, if it's carburated and revs hard to at least 6000 rpm, I'd go 3600. I Need to see cam specs first. Street car shmeet car, I drive around with a 5000, and my last 4200 was tame as a kitten(a rabid, hissing kitten)
Subframe connectors, ET Street Radials, 3600 stall, 4.10 gear, 700R4....It should cut 60 foot times in the 1.50-1.60 range if the rear axle can handle the torque multiplication!
Old Dec 29, 2006 | 01:18 PM
im not sure of exact specs on my cam, i belive its around 312 advertised duration, and i know the lift is over 500. im out of town atm, first time i didnt have my cam card in my wallet
but no it doesnt hold first gear. it boils through first i hit 2nd with in about 1 sec or less, or it will throw me up automatically into 2nd gear. and in 4th gear it kicks me back down when i break 4.5k rpm.
and i have a holly 750 double pumper for a carb.
im still workin outthe bugs. i have manual lock up for the trans but have yet to do manual shift. im tryin to decide if im gonna go with a 6 speed or a t350 or keep 700r4. ill gladly accept any advice =)
ill be home tomarrow night, so i can give exact specs of cam tomarrow.
93 RedBird
Nov 15, 2015 08:24 AM
colts0455
Sep 22, 2015 02:03 PM
tommalcolm
Sep 11, 2015 03:39 PM
fundone2000-RZ
Pacific
Jul 21, 2015 07:21 AM
