Tach is off??
Old Sep 15, 2004 | 05:52 PM
  #16
Dave89IROC's Avatar
Re: Tach is off??
Originally Posted by kandied91z
i'm not talking about being incorrect...i'm talking about flat out not moving until you drive for a few miles. then it's good.
jeff, since your 91 is electronic, I would think it is you VSS going bad
Old Sep 15, 2004 | 08:29 PM
  #17
stone4779's Avatar
Re: Tach is off??
BTW I dont know if he knows this but the sensor is in the tranny....dont know exactly where but I think its in the tail...can anyone verify this?
Old Sep 15, 2004 | 08:55 PM
  #18
dj haf's Avatar
Re: Tach is off??
hmm...my speedo doesn't work unless im moving at 10mph+... if your speedo isnt working for a good 10 miles, i wouldn't doubt it's your VSS acting up on you. $60+ bucks to pick up a stock replacement at the dealership. just put the gear from the old VSS into the new one when you replace it.
Old Sep 15, 2004 | 09:31 PM
  #19
Dave89IROC's Avatar
Re: Tach is off??
yup, right where the cable used to go on the pre 89's
Old Sep 15, 2004 | 09:47 PM
  #20
Ben91RS's Avatar
Re: Tach is off??
Yep, that sounds just like a bad VSS. Mine does the same thing, but I'm cheap . The VSS is located in between the tranny mount and the tailshaft (kind of) on the driver's side.
Old Sep 16, 2004 | 02:21 AM
  #21
kandied91z's Avatar
Re: Tach is off??
what is vss? what else does it control.....doesn't bother me but might be worth fixing.
Old Sep 16, 2004 | 06:17 AM
  #22
Dave89IROC's Avatar
Re: Tach is off??
vahicle speed sensor
speedo, cruise, ect.
Old Sep 16, 2004 | 09:21 AM
  #23
Ben91RS's Avatar
Re: Tach is off??
From Chilton's manual:
The VSS is located on the transmission and sends a pulsing voltage signal to the ECM which is converted to miles per hour. This sensor mainly controls the operation of the TCC (torque converter clutch) system, shift light, cruise control, and activation of the EGR system.
Old Sep 16, 2004 | 12:36 PM
  #24
kandied91z's Avatar
Re: Tach is off??
so it controls how the torque converter works as well?
hmm, sounds like it should be fixed then....i can deal without a speedo, not the rest though.
mr28
Apr 20, 2016 05:44 PM
Zee man
Feb 12, 2015 07:07 AM
ldtantlinger92
Jan 19, 2015 01:26 PM
mr28
Nov 23, 2014 11:11 AM
