T-56 swap
Old Feb 16, 2003 | 03:09 PM
bad91383Z's Avatar
T-56 swap
i am wanting to swap 700R4 for a T-56 and am wondering if a T-56 from a '97 C-5 work? I know that the input shaft will have to be replaced for the swap and the cross member is different. Thanks
Old Feb 16, 2003 | 03:16 PM
BlowBye's Avatar
Nope, wont work. Not only is the input shaft different, i believe the LS1's use a different type of fork. I also believe the flywheel is a 2 piece rear main seal while your's is a 1 piece. IMO its not worth it. Find a set from a 94-97 F body, Will be much easier on yourself.
BTW the bellhousing is off.
Old Feb 17, 2003 | 07:32 PM
TheGreatJ's Avatar
Input shaft, bellhousing, front plate, clutch hydros, and the clutch itself are all different. The input shaft alone is $380 from GM. Unless you can get it for free, it's not worth it.
G-BODYT56
Jan 14, 2022 11:14 PM
David Dempsey
Mar 12, 2016 12:42 AM
blac94Z
Nov 4, 2015 01:59 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
