Switching to carb, Help!!
Old Aug 14, 2005 | 09:07 PM
streetheatz28's Avatar
I have a 88 sport coupe camaro with a 305, I am dropping a carbed 355 in the car what will i need to do this? If i'm not mistaking the fuel pump is inside the gas tank. Any help will be appricated. Thanks.
Old Aug 14, 2005 | 10:56 PM
Runin2Nite's Avatar
Re: Switching to carb, Help!!
i'm lookin at doing the same thing, from what i understand motor and trans mounts are a good idea. and are you running with the same trans, cause you might need a new kick down plate
Old Aug 15, 2005 | 03:01 AM
Chris9450's Avatar
I'm not sure about the cable, I think you'll need a new one. You can, I repeat, CAN USE the efi fuel pump in the tank. Get a good fuel pressure regulator with a return port for the excess fuel pressure to go back to the tank and you'll be set. Both fuel lines are in the engine bay already, just use a block off plate on the block where the mechanical fuel pump would go. The efi pump works much better than a mechanical pump imo. You only use 5-10 psi and when you really stomp it you'll have all that extra pressure waiting .
IndyZman
Oct 22, 2015 02:17 PM
Kawi
Sep 28, 2015 09:01 AM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
