How much would a cam do
Old Aug 10, 2005 | 11:15 PM
bmillington's Avatar
Trying to figure out whether it worth buying a cam for my engine when I'm going to make a 383 out of it in two years.
Correct me if I'm wrong but I dont think I can get a cam that would be perfect for my future 383 and good for my curent engine, (350 HSR intake, 1.6 rockers,Trick flow heads, 1 5/8 headers).
Is there a cheap cam that would be worth it for only two years. I just think my stock cam is killing me with my heads and intake.
Thanks for any opinions.
Old Aug 10, 2005 | 11:25 PM
blackztpi's Avatar
Re: How much would a cam do
u can always go with something like a hotcam. CC305, XE 224/230. those wont make great 383 cams, but it will still run well. just not as well as a cam for a 383. i'd go ahead and do a good cam. you might be soo happy with it that you can hold off on the 383 for a while. if the 350 is setup right, it wont be too much less power than a good 383. and you can save some cash. save the money for when the 350 goes. then you'll have enough for the real goodies... this is all assuming you are like 80% of us who are on tight budgets. lol
Old Aug 10, 2005 | 11:28 PM
DevilsAddvocate's Avatar
i have a zz4 cam im looking to get rid of, 75 bux shipped to ur house
208/221 @.050
.474/.510 w/ 1.5 ratio rocker
112 LSA
lemme know
Old Aug 10, 2005 | 11:30 PM
very tight still in College, got like 20 years to go.
Old Aug 10, 2005 | 11:37 PM
hmmm how much are u willing to spend maybe we can work somethin out
Old Aug 10, 2005 | 11:38 PM
doug791's Avatar
do you already have all of those other things on your engine or is your motor stock now?
If your motor is stock now then no you cant really get a cam that will work for both, not well anyways.
Why exactly is it you want a 383? You usually only bother to do that when you have to rebuild the motor anyways, not worth the horsepower gains if your motor is in good shape.
Old Aug 10, 2005 | 11:49 PM
Motor has about 160 K miles so I'm planing on rebuilding in about two years when I get a real job, again. In the future would like a light weight completly balanced rotating asymbly, with a little more displacment.
It is all stock bottom end, but I have had the heads, header, and intake for about a year. Along with learning how to burn my own chips. Would like a little more power, of course. Only 263HP @ 4800rpm / 328Torque @ 1900rpm.
Old Aug 10, 2005 | 11:51 PM
DevilsAddvocate your offer is tempting. what kind of condition is it in.
Old Aug 11, 2005 | 07:10 PM
doug791's Avatar
Why in the world is your torque so low if you have aftermarket heads, a hsr and roller rockers, something doesnt seem right there man, stock tq was 345 at the crank
Old Aug 11, 2005 | 09:39 PM
221HP @ 4300rpm / 321Torque @ 3300rpm.
is what I hade before installing all that stuff. Thats why I'm looking at the cam. I'm also trying to get better data logging for modifing the chip.
Old Aug 11, 2005 | 09:43 PM
85_305's Avatar
Whoa.. something is deffinently not adding up Like Doug said, your car puts out like 345lb's from the factory. With some good heads, intake and headers you should be WELL over 350hp and 390+torque.
A cam in a third-gen is ALWAYS a must. Our cars have, for the most part, pretty darned shatty cam's.
Old Aug 12, 2005 | 08:13 AM
Do you think the problem is in the cam and chip, or should I be looking at anything else.
Old Aug 12, 2005 | 04:35 PM
91-Z28-L98's Avatar
Low torque is probably due to the HSR. It eats a little bit of low end torque but makes up for it with better high end flow. Having your max torque at 1900 RPM is a bit wierd for sure though. Probably due to the mismatch between cam and the rest of your system. Get a cam that is set for higher end flow as well and you will probably not lose any low end torque but will produce a decent amount more power.
Old Aug 12, 2005 | 09:44 PM
85_305's Avatar
I honestly don't know. What RPM range are your heads good thru? If those aren't the problem.. then I am thinking it HAS to be the cam
Old Aug 12, 2005 | 10:14 PM
doug791's Avatar
I think everyone is on a different page here? or maybe im lost? i took this post to mean he was making 321 to the wheels before he put on heads rockers intake etc, so now hes probably making a hell of a lot more then that.
Your engine is now definitly designed to operate in a higher powerband and youre going to need a cam that matches the powerband of whatever heads exactly it is you have.
The car may run fine without a custom burned chip setup for your car, however you may also be losing 50 hp by not getting that tune. Just remember the only way to get a good custom tune is on a dyno in real time.
