suggestions on how to make easy bolt on horse power for cheap
Old Mar 12, 2005 | 04:19 PM
  #31
85_305's Avatar
Re: suggestions on how to make easy bolt on horse power for cheap
Koolness Thanx for the site, I now know what the rocker ratio is
Old Mar 12, 2005 | 04:52 PM
  #32
IROC-T's Avatar
Originally Posted by 85_305
IROC-T your saying that if I get 1.6 rockers (after looking into it) I could avoid the need of having machine work done to my heads??
NO,I meant you might need clearance work done to the heads if 1.6's are used. The last paragraph in the preveious artical talked about heavier springs and push rods,(even with stock push rods)the openings for the rods may need to be relieved or they could bind.
Old Mar 12, 2005 | 05:05 PM
  #33
85_305's Avatar
Ya, I read that a bit about using heavier spring, and the part where the whole engine could end up binding wned:
Old Mar 13, 2005 | 10:00 AM
  #34
Formula350ks's Avatar
As stated before the larger TB will do nothing for you. An aftermarket MAF will not be worth the money at this point. If you don't have exhaust already do that first. You will notice a big difference. Then start with some K&Ns either drop in replacements or a cone style with a 3 inch tube over to the fender well depending on how your stock set up is. Some ignition mods like the MSD coil, cap, rotor, wires, and HEI module won't set you back much either and will help out now that you are getting more air in and out of the engine. The air foil may or may not make a difference. I have one and can't tell a difference on my car with cold air intake and exhaust. Good Luck!
Old Mar 13, 2005 | 11:55 AM
  #35
85_305's Avatar
What the hell is an airfoil? I hear people talking about them all the time..
Old Mar 13, 2005 | 12:22 PM
  #36
a piece of aluminum or sometimes plastic I guess that goes directly on the front of the throttle body to smooth out turbulance in the air coming in.
Old Mar 13, 2005 | 03:24 PM
  #37
IROC-T's Avatar
Don't worry about it,you don't need/want one! They only help at WOT and then very little,not worth the money unless someone has one they are going toss forget about it.
Old Mar 13, 2005 | 08:15 PM
  #38
85_305's Avatar
Oh, that is surprising everyone in this thread is saying they do nothing because every other time I hear people talking baout them, they only say good things abou them. Not to mention that near EVERYONE that mods their car has one! (well, on their TPI cars I believe..)
Old Mar 13, 2005 | 10:52 PM
  #39
IROC-T's Avatar
Yep! Your right,that's true I even have one in my old 48mm TB. That doesn't mean that it's worth $50 and that it even works(it does help at WOT)and if it does what kind of gain,not the 10hp claimed. I would not buy one today knowing that they don't work,I bought mine when they first came out and everybody had to have one. Besides spending the money on something more important,and when the time comes buy a 52mmTB (most after market TB's have them built-in)then you'll have one.
Old Mar 14, 2005 | 10:07 AM
  #40
mako350Z28's Avatar
This is an air foil
clicky
Old Mar 14, 2005 | 03:30 PM
  #41
85_305's Avatar
Thanx for the info guys
And thanx for the pic
F'n1996Z28SS
Aug 23, 2023 11:19 PM
InfernalVortex
Jan 17, 2015 09:35 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
