Steering Column Loose
Old May 27, 2004 | 07:05 AM
buzz12586's Avatar
My steering column is loose in the vertical direction. It is a tilt steering wheel and when it is down to where I like it I can push up on the bottom of it and it will move up and then come back down to where I had it. Is this normal or do I have a problem with the column?
Old May 27, 2004 | 07:44 AM
Stephen 87 IROC's Avatar
There are 3 screws inside the column that are loose. They'll be very small torx head screws and they're very hard to get to. Most of the column needs to be dissassembled to reach the screws.
Old May 27, 2004 | 09:21 AM
trackbird's Avatar
As I remember, mine had 4 screws, but I could only get to 3. They are designed for a "torx socket" to be used to tighten them. I managed to use a standard 6 point socket and it worked very well. It will work in a pinch (it did for me).
Good luck!
Mine came loose from hanging on the steering wheel in corners since the seats offer no support for that stuff. That was my best explanation.
Old May 27, 2004 | 05:31 PM
buzz12586's Avatar
Thanks guys. Now I just have to look for these screws.
Old May 27, 2004 | 06:37 PM
greezemonkey's Avatar
Yes there are 4 screws, inverted torax is the name of that fastner,
Once these work loose you`d better loctite them or they back out quicker the next time. These screws are about three inches long and thread into aluminum so they strip if torqed alot. The lock collar must be removed to access the fourth screw. It`s a lot to take apart if you a first timer. Good luck
Use loctite or lose your nuts
Old May 27, 2004 | 07:27 PM
Dave89IROC's Avatar
http://www.thirdgen.org/newdesign/te...ngcolumn.shtml
IndyZman
Oct 22, 2015 02:17 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
jackpawt883
Sep 10, 2015 08:53 PM
rideordie
Sep 7, 2015 08:22 AM
War Engine
Aug 28, 2015 06:04 AM
