Stealth Ram or LT1 intake?
Old Dec 8, 2002 | 07:38 PM
1968firebird's Avatar
What should I get a Stealth Ram or an LT1 Intake? Which is cheaper and better for the long run. Also, easiness to install. Thanks.
Old Dec 8, 2002 | 07:40 PM
and also
this is going onto an 88 L98 with tpi
Old Dec 8, 2002 | 09:13 PM
Geoffmj's Avatar
I dont know which is easier, but I have an LT1 intake with TB, injectors and fuel rail if your interested
Old Dec 8, 2002 | 10:11 PM
87camracer's Avatar
i would go with the lt1 intake because if you have a bird it will fit under the stock hood where as the stealth ram wont. if you go lt1 you will need to convert it to a distributor clad engine. the real lt1 engine didnt have a distributor like a regular 350 does. your best bet is to order one from www.lt1intake.com. the guy converts it himself, paints it whatever color you want and i believe sends installation instructions as well. if you already have a running tpi setup all you will need to swap this on is a throttle body. hope this helps.
Old Dec 9, 2002 | 08:08 AM
aklim's Avatar
Personally, I'd go with the ACCEL Superram intake system.
Old Dec 9, 2002 | 11:48 AM
S. Holley's Avatar
explain this LT-1 intake conversion... I can't find it ??
Old Dec 9, 2002 | 12:46 PM
bigmike92z's Avatar
www.lt1intake.com is where he pointed out earlier.
thats john millican and he's been doing those for a while now. the good thing about those is that, like he mentioned, it fits under a stock bird hood. also, theres been quite a few people doing it this way so there is a good amount of info out there to be found. also, john is always present on his boards over at www.se-thirdgen.org or on thirdgen.org to answer questions about it.
Old Dec 9, 2002 | 12:50 PM
Question
ive heard from a few different sources that it does fit under the stock hood
Old Dec 9, 2002 | 01:17 PM
bigmike92z's Avatar
it will require some chopping...
i guess we should say "it wont fit under the stock hood without modification."
Old Dec 9, 2002 | 01:44 PM
87camracer's Avatar
think of the stealth ram this way, it is basically a tunnel ram setup with a EFI plennum on top. so if a tunnel ram is too big to fit under your hood then this is also too big.
Old Dec 9, 2002 | 11:51 PM
Jerod Matlock's Avatar
The stealth ram will fit under the stock camaro hood better than the firebird. On my formula, I simply took material from the top and bottom of the plenum. I also shaved 1/16" off the base (shortened runners). Furthermore, I neatly cut out some braces on the underside of the hood. I clear by about 1/16" at the front passenger side of the throttle body. For more information and pictures, search for JMatlock88 (me) on www.thirdgen.org. Later.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
oldschool
Feb 9, 2016 09:21 PM
LT14LIFE
Feb 9, 2015 09:35 PM
rjc1629
Jan 27, 2015 10:46 AM
