Starting Problem
Old Mar 25, 2006 | 09:56 PM
HPP88's Avatar
Starting Problem
Well I just finished putting an 88 305 into my 85 iroc. Well the problem is it will start but only run for a few seconds then quit. The fuel pump runs abnormally long but it has good pressure, I checked it with a gauge. Replaced the filter too. Spark is good, I used a spark tester and a timing light. The motor is in time.
It seems to quit running when the cold start injector stops spraying. I removed all the other injectors and it does the same exact thing. But when I only remove the cold-start there is nothing at all. So basically I'm trying to figure out why won't the other injectors spray?
Old Mar 26, 2006 | 06:53 PM
HPP88's Avatar
Re: Starting Problem
Well today I pulled up the fuel rail and the injectors weren't spraying, only the cold start. So I switched the connecter from the cold-start to another injector turned the engine over and that injector sprayed. Why aren't the injectors getting the signal to fire?
Old Mar 27, 2006 | 06:42 PM
respectirocz's Avatar
the cold start injector has a thermo time switch, it is not controlled by the pcm at all, your problem is not related to the cold start injector
u need to check to see if the computer is recieving all the signals it needs to properly fire the injectors, i.e. ECT, MAF, IAT, TPS, and distributor reference signal
check if the wiring for the 4 sensors and your distributor are all hooked up to the proper harness going to your computer and the computer is getting power
Old Mar 27, 2006 | 08:06 PM
HPP88's Avatar
I did happen to put a small cap hei into my car at the same time as this. But I matched up wires A,B,C,D from the old connector to the new. How do i check to see if the computer is recieving all the signals? And what is the ECT?
Old Mar 28, 2006 | 09:22 AM
engine coolant temperature sensor, aka cts, coolant temperature sensor
i've never messed with my dist, i know theres a wiring diagram somewhere
Old Mar 29, 2006 | 12:43 AM
HPP88's Avatar
Well it was the 4 pin connector on the distributor. Got it started. Thanks
Alex Barnes
Jan 24, 2015 10:21 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
HCz28
Jan 11, 2015 11:21 AM
97z28k&N
Jan 9, 2015 04:58 AM
97SSdude
Dec 31, 2014 07:43 PM
