Starter Solenoid -- "S" or "R"?
S is for "start"
R(sometimes I) , well, not sure on R, but I is for ignition(points cars used this to bypass the ignition resistor on crank(oil filled coils don't last long with full 12-14v to them, so the resistor dropped feed voltage will running to ~10v, but they still needed 12+v to start the engine)
Beautiful thanks!
Another question:
There are 2 wires that T-off the wiring harness behind the engine, and they drop down behind the engine in a metal tube. One is a thicker wire with a large-ish ring terminal, and there is a pair of smaller wires that terminate togother in a shared smaller ring terminal.
I already have the large starter wire coming from the battery located. Do both of these go to the starter? One to the large lug, and the other to the small terminal "S" for Solenoid? Or is there another single wire somewhere that goes to "S"?
Thanks!
Another question:
Thanks!
Beautiful thanks!
Another question:
Thanks!
Another question:
Thanks!
what kind of car?
Except for the wire from the ignition switch that actually engerzies the starter (agreed- it's usually purple in color) pretty much everything else goes to the same big terminal on the starter as the main battery wire. I'm talking about cars from the modern era here- late 70s or newer.
They use several wires (often with fusible links mounted in-line) to draw power for various other electrical needs in the car. The main post on the starter is just a convenient place for them to draw power from. Yes, they go through the same metal tube down by the starter as the purple starter wire does (the tube is a heat shield).
Formula Steve
Sep 19, 2023 08:31 AM
jackpawt883
Sep 10, 2015 08:53 PM
350350
14
Aug 11, 2015 12:03 PM
