starter question
Old May 30, 2003 | 03:34 PM
kandied91z's Avatar
Question starter question
alright, i still can't get the car to start well, but i can start it 2 out of 10 times now.
all grounds are testing good
all wires are tight and reading the right voltage
battery tests good and works well in other vehicles
starter tested good
alternator tested good
i can now get the car to start however it's very hard....almost as if the teeth on the starter aren't meshing with the flywheel just to give an idea?
if the starter is checking out good what else can cause this?
Old May 30, 2003 | 06:47 PM
TheGreatJ's Avatar
Is it grinding or binding up? If it's binding up then you need a shim above the starter to get it farther out on the flywheel teeth.
Old May 30, 2003 | 07:29 PM
Nitromethane's Avatar
Grab a 1/8" drill bit - get under the car and slide it between the teeth on the flex plate/flywheel and starter, it should fit perfectly, if it doesnt fit, u need to shim the starter out a bit cuz its bnding, if its got too much play, shim the starter inwards to close the gap - most flex plates arent 100% round, so if theres too much clearance, theres gonna be pointa on the flex plate where it wont start.
warmeck
Feb 5, 2015 11:04 AM
jermaine_rashad
Advanced Tech
Jan 4, 2015 02:32 PM
Jeff1904
Jan 3, 2015 12:00 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
