Speedo calibration??
Old Sep 5, 2007 | 08:26 PM
scooters97ss's Avatar
I just bought a 1990 IROC that a previous owner put 4.11:1 gears in. It is a blast to drive but the speedo is wacked out. Can I buy a set of speedo gears or something to get it working right??
Old Sep 6, 2007 | 09:06 AM
Z28SORR's Avatar
Short answer is yes. Don't remember what year they changed. If it has VSS you can get a module that's adjustable. If it's still cable driven, (I don't think so), you can get gears from GM that go in the trans. tail shaft. Check the 3rd Gen board.
Old Sep 6, 2007 | 09:23 AM
Rice Killer87's Avatar
1990 is electrical,no speedo gear.
Old Sep 6, 2007 | 03:50 PM
It has VSS. Do you know where I could get an adjustable module?? I thought this was the 3rd gen board.
Old Sep 6, 2007 | 04:09 PM
krisb410's Avatar
All you have to do is find out what drive and driven gear combination will work for your setup.
This link should help http://www.700r4.com/speedoCalc/speedocalc.shtml
Old Sep 10, 2007 | 12:59 AM
Kevin91Z's Avatar
3rd Gen Tech Moderator
It is electronic, but it still uses a plastic drive gear and driven gear on the tailhousing to make the electronic VSS work.
Old Sep 11, 2007 | 09:50 PM
Tex95Z's Avatar
thats what I was gonna say. I think what Z28SORR meant was Thirdgen.org
Sep 27, 2015 01:55 PM
mmf_1013
Sep 12, 2015 08:56 PM
CamaroSS30thAnn
Sep 8, 2015 04:43 PM
LazyLemming
Aug 29, 2015 07:36 PM
4586
Aug 24, 2015 11:04 PM
