So, what should my ignition coil ohm out to?
What should a good ignition coil Ohm out at? Just want to test it. Gonna replacing ignition parts just cause I am ****. I'm gonna get new wires and ignition module and distributor cap. Maybe a Ignition coil too, but only if it tests out bad. Also, what brands do you guys like? I used to get Accell stuff for wires and what not. They seem to be really good. I will probably get a AC Delco cap and ignition coil. I'm not trying to upgrade over stock Ignition.
Re: So, what should my ignition coil ohm out to?
Less than 50 ohms..Accel coils are good, better than stock, also use Accel Super Stock wires, they have a spiral wound steel core putting much more energy at the plug. Make sure the cap and rotor have Brass inserts not aluminum..
