Smog Equipment
Old Mar 17, 2003 | 04:35 PM
JBIRD91's Avatar
Smog Equipment
Hey thanks for the advice this is why i got a computer lol. anyway i was needing some info about removing the smog pump and a.i.r system on my 91 305 tbi just wondering if you have to do anything to the computer or egr vavle. think im going to buy the headers without the a.i.r system. im in florida no inspection just sighned a sheet that said i would not remove the cat. thanks to any advice
Old Mar 17, 2003 | 05:37 PM
Marc 85Z28's Avatar
No modifications need to be made to the AIR system or ECM. The AIR system is an output only, so it won't affect anything once removed. However, you will have a problem with the serpentine belt system. You either need to fabricate an idler pulley to go in place of the removed pump, or you could relocate a few items and run a different belt.
You will also need to plug the holes in the manifolds or like you said, buy headers without the tubes.
Old Mar 17, 2003 | 06:22 PM
JBIRD91's Avatar
Wink
cool but can i just run a shorter belt and i hear that some of the a.i.r systems have tubes that go in to the back of the heads. i want to keep it where i can put it back on if i have to.
Old Mar 17, 2003 | 06:43 PM
Matt87GTA's Avatar
Thumbs up
Yep, just run a shorter belt with the AIR pump and related pipes removed. You can also buy some pipe fittings and remove the stainless pipes that go into the manifolds if you really want to clean it up and free up some space. You can just leave the pipe that goes down to the cat in place and cap it off with a pipe cap but the ones that go behind the engine are rubber on yours IIRC, so just yank it all and throw it in a box and stash it in the shed.....
Check out the tech articles at www.thirdgen.org for more info on rerouting the belt and the proper sizes for the pipe fittings for the manifolds (1/4" NPT I think).
Old Mar 17, 2003 | 06:51 PM
TheGreatJ's Avatar
The Ford 302 is the only engine I know of that has the AIR tubes in the heads, and that's only on the truck motors. FYI
IndyZman
Oct 22, 2015 02:17 PM
cmsmith
Sep 14, 2015 09:25 PM
john henry
Aug 14, 2015 08:33 AM
john henry
Classic Engine Tech
colts0455
Jul 8, 2015 12:21 AM
