Shift Knob Thread Size
Old Feb 4, 2004 | 01:04 PM
buzz12586's Avatar
Shift **** Thread Size
I just installed my Hurst Billet/Plus shifter for my T-5 and I was thinking about getting a new shift **** for it. Anyone know the thread size on it??? I looked through everything that came with it but can't find the size. Thanx.
Old Feb 4, 2004 | 01:12 PM
CODY BEHNKE's Avatar
I am not sure what the T5 handle thread size is but, you can go to MR.Gasket.com and look in the hurst catalog it will show you there.
Old Feb 4, 2004 | 04:45 PM
Ville H. Valo's Avatar
I got one of those, then i got a Shorter rod off of ebay, it was well worth it. Dropped the ball another 3-4 inches.
The thread on a stock T-5 is 16mm x 1.50
Old Feb 4, 2004 | 09:06 PM
buzz12586's Avatar
I don't need the stock size. I need the size of the Hurst one. It is smaller.
Old Feb 4, 2004 | 09:22 PM
Black6SpdTA's Avatar
Give Hurst a call.
I'm not doubting you, but I was almost sure that all aftermarket shifters were stock thread size. I know Pro 5.0 ( ), B&M, and 6spd Hursts are...I'd double/triple check.
-Corey
Old Feb 4, 2004 | 10:56 PM
No, Hurst it for sure smaller, i have the hurst shift rod, it is really different...
Old Feb 5, 2004 | 07:19 AM
Ah...learn something every day
Old Feb 5, 2004 | 08:02 PM
buzz12586's Avatar
I found it at the website. It was 7/16 - 20
Thanx guys.
Old Feb 6, 2004 | 05:01 PM
jcurrieirocz's Avatar
Originally posted by Rippin92RS
I know Pro 5.0 ( )
-Corey
MMMM yes yes they rock
A hurst doesnt even allow you to use your stock **** thats not cool at all...cawlk up another point for PRO 5.0!
But someone said buying a shorter stick from ebay...isnt that defeat the purpose of buying the aftermarket short throw shifter in the first place as your screwing up the goemotry of the shifter and it would be harder to shift. You mise well just cut a chunk off the stock shifter and tread the shaft. The reason a short throw shifter works so well is they move the middle movement point of the shifter up so the lower part of the shifter is longer thus makeing the throws shorter but you keep the same ease of shifting movment. I guess tho if you like cutting about 1/2" off a short throw shifter it prob = the same throw as cutting 1" off a stock one and you would mess up the geometry about the same.
Old Feb 6, 2004 | 07:07 PM
A Pro 5.0 has about 2" of thread already. The stock, or an aftermarket, **** only needs ~7/8" so you can already lose about an inch or so, using the supplied stick. I'd never buy a short stick. Although Lou's and a Pro 5.0 are supposed to be heaven together...
Old Feb 6, 2004 | 11:30 PM
buzz12586's Avatar
All I know is that I love this shifter (the Hurst). It feels so much better than my old one. The length of the stick is the same, but the throw (distance between gears) is a lot shorter. It feels amazing.
Old Feb 13, 2004 | 03:35 AM
yes i know ive been contiplaiting wheather to cut mine down...but i dont want to incase i dont like it. Whats so big about lou's stick anyhow??? i mean how much lower is it compared to the supplied one if say you cut it...or does it have a bend in it or something??
Old Feb 13, 2004 | 07:21 AM
No bend, just a straight stick. Supposed to be really short, that's it. I think LS1 Speed has them -- www.LS1Speed.com
HectorM52
Jul 30, 2017 11:46 AM
PROJECT X
Apr 17, 2015 12:13 AM
mattstrike
Mar 11, 2015 07:33 PM
Jason Short
Jan 19, 2015 06:34 PM
redz_02
Jul 24, 2002 09:42 AM
