serpintine water pump....how can i tell?
Old Aug 19, 2003 | 06:44 PM
StealthElephant's Avatar
I bought a water pump from Pep Boys....how can I tell if it's a serp pump and that he didn't give me the wrong kind?
Old Aug 19, 2003 | 07:21 PM
IROCZZ3's Avatar
You can always pull off the back plate and see which way the impellers are pointing, although I'm not sure which way is which.
I do know that the standard rotation pump has the 2 alternator bracket mounting bosses cast into them...the reverse rotation pumps do not. I guess you can check that if you don't wanna pull the rear cover off. HTHs.
Old Aug 19, 2003 | 07:31 PM
thanks....so if the one i got is right there should be only 1 bolt hole for mounting my alt bracket?
Jeff1904
Jun 5, 2016 05:00 PM
93 RedBird
Nov 15, 2015 08:24 AM
PopoFormula
Oct 12, 2015 04:19 PM
colts0455
Sep 27, 2015 01:07 PM
