Self-Align or Not?
If your heads use pushrod guideplates bolted under the rocker studs OR if the heads themselves have oval-shaped pushrod holes that prevent the pushrod from moving side-to-side you want NON-self aligning rockers.
You want to use only ONE method of locating the rocker arms over the valve tips or risk tearing up parts from two locating methods "fighing" eachother.
2QUIK6
Jul 15, 2015 07:46 PM
