SBC with geardrive
SBC with geardrive
Hi guys i know that this the lt1 forum but i need a fast answer to my question. I have a sbc with a summit gear drive now my question how do i install the thrust bearing on the locking plate the instruction that came with it does not tell you. when i install the locking plate on put the thrust bearing is it supost to be loose and does it be loose to touch the cover or what i am confused. thanks
Yah, can't tell if your talking about a thrust bearing or a cam button.
The thrust bearing goes between the cam gear and the block (some need machining). And the cam button goes between the cam and the timing cover.
Post the "Summit" link to it.
Bryan 94 Z28
Advanced Tech
Oct 8, 2002 11:46 PM
