Running Rough
Old May 2, 2007 | 05:24 PM
DOUGDREZ28's Avatar
Running Rough
I Have A 91 Z28 That Has Been Running Rough. I Have Changed The Plugs, Wires, Cap, And Rotor , Ive Also Put Full Tank Oh High Test Gas In With Gas Cleaner And Changed Ignition Module. Nothing Changed Does Anyone Have Sugestions.
Old May 3, 2007 | 07:45 PM
joeSS97's Avatar
Check your egr valve.A little better idea of when its running rough would help...Accel...cold?
Old May 5, 2007 | 08:05 PM
Rage's Avatar
Check for vaccum leaks. Also, I know it was running rough before you did all of the work, but check your firing order, you may have them crossed.
Also, I know that when my fuel pump went out, it would work but made it run really bad for a few days before it finally quit working all together. It was kinda odd, they usually just stop working. Did you change the fuel filter? Air filter?
Old May 6, 2007 | 09:44 PM
DOUGDREZ28's Avatar
IT RUNS WORSE WHEN ENGINE IS WARM-- BUT HAS RUFF IDLE ALL THE WAY THROUGH RUNNING AND DRIVING
Iamherefornow
Jan 26, 2015 04:57 PM
1775.Z28
Jan 11, 2015 10:51 AM
Scottylt1
Jan 8, 2015 02:48 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
Scottylt1
Dec 4, 2014 12:31 PM
