running rich
Old Aug 20, 2005 | 05:32 PM
LoudmouthSS's Avatar
running rich
Ok so i finally got my car to run and idle..yay
now...it runs alittle rich, im guessing because of the 30 lb injectors.
Any tips or tricks to get her to run not so rich.. i changed the prom over to 30lb injectors...i decreased the fuel pressure.. anything else i can do?
Old Aug 20, 2005 | 10:54 PM
Runin2Nite's Avatar
Re: running rich
how are the o2 sensors???
Old Aug 21, 2005 | 01:54 AM
iansane's Avatar
Re: running rich
What do you mean? Did you just change the injector constant? If you have the ability to do that then just look at the fuel tables and cut back as neccesary...
Old Aug 21, 2005 | 09:37 AM
Re: running rich
No i had my prom sent to TPIparts.net and they did it for me. They also disabled the egr and smog.
Ok about the o2 sensors...should i have one or 2?
They guy who had the car before me coverted it to a 1 cat car...oneday ill put the duel cats back on but for now i cant. So i only have one oxygen sensor (i thought there was supposed to be 2?)
I cleaned it off with some break cleaner and stuck it back in...maybe i should get a new 1..
Old Aug 21, 2005 | 09:38 AM
Re: running rich
setting it to 30lbs helped alot it smokes alot less but it still runs pretty rich.
But it smoked real bad b4 i put the prom in...so if the problems still there...maybe it is my o2 sensor..
Old Aug 21, 2005 | 02:54 PM
Re: running rich
Ok i changed the o2 sensor..no different
DirtyDaveW
Dec 1, 2016 05:37 PM
Iamherefornow
Jan 26, 2015 04:57 PM
Donwest22
Parts Wanted
Dec 12, 2014 05:58 PM
Rich_z28
May 6, 2003 08:38 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
