rev problem
Old Oct 5, 2003 | 09:21 PM
FLIPPINZ28's Avatar
rev problem
okay i have a 92 camaro rs factory 305 i have a msd 6al. when i first drive it it idles high. when it is warm and i rev it it takes a minute to go back to idle. any help or sugestions i also have accel plug wires thanks alot
Old Oct 9, 2003 | 12:48 AM
FishPig's Avatar
you put in an MSD ignition is the coil stock, did you do anything to the comp, is the pedal sticking, are your return springs worn out on your throttle control, and are you still running EGR? Give a few more details.
Old Oct 9, 2003 | 09:47 AM
aklim's Avatar
Try cleaning the TB and the IAC. Then reset the IAC to where it should be and then the TPS.
Old Oct 9, 2003 | 10:37 AM
90rocz's Avatar
I always heard that was a sign of a restricted exhaust, plugged ct.converter maybe. Or even worn rings, but lets not think about that one yet. If you can unhook it you can tell for sure...
Old Oct 9, 2003 | 04:44 PM
FLIPPINZ28's Avatar
hey thanks guys i gutted my cat and cleaned up the tbi and sensors. it is perfect now i also have a stock coil which sucks thanks alot
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
PCLZ28
Dec 24, 2015 05:19 PM
Cam's maro
Mar 24, 2015 08:09 PM
draven666
Nov 26, 2014 07:16 PM
