Replacement carb for 82 camaro
Old Feb 1, 2003 | 11:10 AM
venomcure98's Avatar
My buddy has a 82 camaro with 198k miles on it and it is still on the stock carburater! Well the other day it gave out. What would be the best replacement for the th old worn out 305? Oh it is a 4bbl. any help would be appreciated.
Old Feb 1, 2003 | 11:28 AM
MRZ28HO's Avatar
Exclamation
If it still is, and requires a smog check, the only viable option is to find a rebuilt E4ME. All others are not smog legal. If he plans to, and can, remove the computer controlls and smog equipment ... then any 650 CFM carb will work. Mechanical secondaries are best with a manual, and vacuum secondaries typically go great with autos.
If he removes the conputer controlled carb, he should also replace the distributor with a vacuum advance type (rather than a computer controlled one) to take full advantage of the advancing mechanism.
Old Feb 1, 2003 | 05:15 PM
AutoRoc's Avatar
dytjyt
Me and a buddy slapped a Holley 600 Vac. Secondary/Electric choke unit on my 305. It fired right up on the first hit of the key with 6 PSI of fuel pressure. It probably cost $200 or so and I'm happy with it. It starts right up in our cold michigan climate also. Which is in the below freezing range right now. Goodluck!
mr28
Apr 20, 2016 05:44 PM
Hurin
Dec 13, 2014 07:38 PM
draven666
Nov 26, 2014 07:16 PM
draven666
Nov 26, 2014 07:10 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
