Removing transmission
Old Mar 9, 2005 | 08:26 PM
  #16
derek83z28's Avatar
Re: Removing transmission
can you change and auto out of an 83 camaro z28 and put in a 5 speed stick from a 88 camaro??
Old Mar 9, 2005 | 09:23 PM
  #17
Camaro_Boy's Avatar
when takeing out the clutch pedal u might wanna draw a diagram of exactly where the holes were.. cause if u dont do it 100 % on the spot.. u will **** ureself in the long run.. like me
Old Mar 9, 2005 | 10:11 PM
  #18
derek83z28's Avatar
this 88 camaro is a v6 fuel injection. will it still work? will i need a new drive shaft.
Old Mar 10, 2005 | 07:13 AM
  #19
Camaro_Boy's Avatar
nope i do not think so. but u wont know till u find the length i guess?
go to chevrolet and ask?
Old Mar 10, 2005 | 08:02 AM
  #20
LandryP's Avatar
If the 88 is a 2.8 V6, the tranny bellhousing clutch and flywheel will not work on a V8. The pedals, hydraulics, shifter and console, crossmembers, mounts and driveshaft will.
Old Mar 10, 2005 | 06:50 PM
  #21
ws6transam's Avatar
For the record, that last time I pulled the 700R4 out of my car it took me exactly 59 minutes from the time the car settled on the jack stands until the transmission was on the floor next to the car. This was when I was getting ready to switch to the T56.
The previous summer I pulled the transmission and swapped in a 2700 RPM torque converter, and the total time from car-up to car-down was about three hours, with no assistant. The trick is the Harborfreight Tools transmission jack for $50, a 9/16 swivel socket, and a three foot long 3/8 socket extension. These are the tools that will make your job easy, especially those top two bell housing bolts, which I pull from the bottom.
Victor Lamb
Aug 26, 2017 02:52 PM
Apr 16, 2015 09:57 AM
jmadoll
Mar 3, 2015 10:16 AM
jackpawt883
Feb 26, 2015 09:04 PM
Jul 4, 2005 05:00 PM
