Removing Shifter assembly
Old Nov 15, 2003 | 10:58 PM
iroczinoz's Avatar
I am waiting on my shifter assembly to arrive, but wanted to get an idea if it is easy to remove.
If anyone has done it what kind of things should I look out for and what is the general advice. Do I have to get under the car to replace shifter assemblies or can everything be done under the trim panel that goes over the shifter?
Old Nov 16, 2003 | 03:39 PM
camar0luvr's Avatar
I just got done putting a mega shifter in. replacing the shifter is easy other than hand tools you will need a drill. The only time you need to get under the car is to replace the shifter cable and install the new brackets if going to a ratchet shifter. Hope this helps
Old Nov 16, 2003 | 05:44 PM
iroczinoz's Avatar
I am only replacing it with a stock unit so no need to get under the car as I will be using the same cable. Some a while ago told me I will have to disconnect the transmision cable and I could not work out why.
Why do I need a drill for?
R@mpage
Apr 20, 2015 10:02 AM
Apr 16, 2015 09:57 AM
BigWil
Mar 29, 2015 12:24 PM
pologreen97z
Dec 2, 2014 10:42 AM
